Intravee update ivfw256exp_extras_v6.02-7018.zip
Not yet, but most changes to do with fog lights working with indicators. This doesn't work on z4's anyway.
Also sorted out a few bugs in Firmware.
Is it possible richardP could code the intravee so that the satnav screen stays down when changing music tracks? Infact code it so it only opens when you press the flip button
+1 that would be a great result, find the flipping SatNav a real pain....
Tapatalking...
Reply from RichardP
The Intravee does not 'code' anything, it can control things but it does not code them in the way that, for example, INPA does.
Generally, the Intravee can't stop things happening, it can only make them happen - I you can see the difference! So the Intravee can't stop the monitor coming up - which it does whenever you change track as the radio displays the new track information and this triggers the monitor to come on. It would be possible to have the Intravee lower the monitor again, but this might put too much stress on the monitor mechanism.
Can you use this update as an initial install?
( I want to get an intravee but don't have a cd drive to install any software)
Why do you need a CD player ?
Download the software from link in thread. You then need to download "downloader" software and have a USB to serial cable.
