Intravee UI Help and Setup
Hi All,
I've managed to install my Intravee just yesterday. and it was working great.....
Now curiosity had the better of me and i couldn't get the advanced search to work. So i tried changing the UI. i know i shouldn't have messed with it, but i did :( and now it's set to UI 1
Is there anyone around the north London area who might be able to
a) help me set the UI back to 5 or 6? ( i don't have the software just yet or laptop right now)
b) set the damn thing for advanced searches??
Any help this week or next would be welcome!
This may help:
http://www.intravention.co.uk/forum/index.php?topic=1127.0
You can actually change the UI preference with a special key sequence.
Yes, use the key sequence, that works fine. I put my unit for someone else to test on a UI1 as well, and simply put it back to UI6 using the keys.
Cheers Guys,
I'll give this another shot, but i was under the impression that, once the UI was set via the headunit, It can't be changed back without a PC?
Wll try it anyway.
OK i managed to resolve this problem but not in the usual manor.....
I found this http://www.intravention.co.uk/forum/index.php?topic=1166.0
Looks like i had the same issue were I would see the CD9 appear but was unable to change tracks to set the UI. :?
"I have the same problem with my Z4 Coupe. It was "kind of" working but my menus would flash (did it lots with the TP menu) and sometimes I would lose the playing now menu. So i decided to try to reset the UI(without a laptop and by turning it off, on <> etc), bad move. Now I just get CD Check. I have the CD9 thing and a list of CD1 to CD6 but I can't change or select anything. Its all locked out. The thing is I know I'm going to have to rip out the unit, find the serial number, email you for the download area, wait and then re flash it"
So i have a work around which worked for me. once in the UI setup, press the 'select' key then choose 'random' After a few tries the UI set itself from 1, then 4 then 1 and now it's back on 6. problem solved
:D
You must have a fairly old software version if you still have the flashing issue. That is if you have that issue of course ...
I have a flashing issue where it will occasionally flashs to a cd1... To cd6 screen before returning to the intrevee options. Which it has always done and I am runnIng the latest firmware.
I should clarify, i didn''t have the flashing issue, just the IU problem where i'm wasn't able to select the correct UI, i was quoting from another forum post. Overall i'm pretty chuffed with the introvee, it does everything that i want it too.
Now where do i find that advance featured menu?? :D
