Intravee flash to pass
mac27040
Veteran
 Shepshed
Hi,
I have spoken to RichardP regarding intravee and he thinks it may be possible to sort out the flash to pass on pre-facelft car when fitting facelift headlights. To do this he needs an IBUS log from a facelift z4 for flash to pass & one from a facelift car.
Is there any who can send the Log to me?
To take an iBus log do the following :
- Connect up the Intravee to your PC and run the downloader program as if you were updating the firmware.
- In the downloader select File, Expert Mode. The first time you select Expert Mode you will be prompted to enter a log file prefix name, use your forum name or something that allows you to be easily identified.
- In the downloader select File, Start Log, select file name and location.
- In the downloader select Controls, Run emulator.
- In the emulator dialog press the button "IBUSDON".
- perform the action you want to log, in this case just let the radio play for 1 minute.
- In the emulator dialog press the button "IBUSDOFF".
- Close the emulator dialog.
- In the downloader select File, End Log.
You should now have a log of all ibus activity between selecting IBUSDON and IBUSDOFF in the emulator.
