Intermittent roof problem
stevedruidstone
 Cardiff
so, first issue was the usual roof motor pack in. The front release was ok and the shelf micros witch seemed ok with no flashing orange. In the first check my mechanic found a weak battery charged it up and Roberts your mothers brother. Then it did it again but this time the battery is fine. The issue is that I can hear the dingus working in the back and the Bowden cable looks fully seated. Any suggestions before the dreaded removal?
Check the fuses...
Get a new battery...
Check your drains are not blocked, you may have water ingress into the motor if drains are blocked....
Maybe roof out if none of the above! :thumbsdown:
