davidfairhurst
Evening guys
I bought an e85 2.2 04 plate around 6 weeks ago.
I got it quite cheap knowing it had issues.
It’s got an MOT until next March but has issues which I’m in the process of trying to fix.
I bought it as a project or keeping it as a donor car for spares.
One issue I’m having problems with is a misfire.
The car runs great for around a mile and a half then the misfire starts. Turn it off for a minute, start it up again drive it and all good again for a mile and a half then misfire starts again, this happens strangely more or less exactly at the same distance travelled.
Have scanned the car and following codes say
DME firing cylinder 1 code 27CF
DME misfire cylinder 1 code 2742
DME interface EWS 3.3 code 27A4
Spark plugs changed, coil packs swapped round to check, injector replaced, but still misfiring on cylinder 1
I would like to try to fix this before looking at other issues with the car. I’m thinking DME/ECU issue.
I got no history of what has been done to the car in the past.
Would appreciate any advice guys please if that’s ok
Dave
Dave
