Hi guys,
Hoping someone can give me some tips on where to start solving this one.
2003 Z4 3.0i 111k miles
My indicators sometimes don’t cancel, leaving me driving up the road flashing left and right trying to get them to stop. I replaced the switches with a used unit and thought this had solved the problem but it’s back. Sometimes they cancel, sometimes they don’t. (Neither auto cancel or by trying with the stalk).
Now more gremlins have joined in, also intermittently. When dipping from high beam the blue dash light sometimes stays on. Same with the front fogs. I can turn them off but have the green dash light stay on. On a recent drive my dash lights were dimming themselves every ten minutes and would only correct when I scrolled the dim switch up and down a couple of times. When the headlights are on normal dipped) there’s no tell tale light on the dash - should there be a green headlight symbol?
The car battery is only a couple of months old and I think the alternator is OK as never any starting issues as a daily driver. Car was just parked up for a week and started first time.
Is this likely a control module issue (if so where do I look)? Or is a bad ground somewhere more likely? Any other likely culprits?
I suspect this’ll be one for my local auto spark to sort unless there’s a known fix I can attempt.
Thanks for any pointers.
