I have an intermittent Charge indicator light on my 2007 3.0i. I'm assuming my alternator is on its way out,.....but before I order a new one,....(I will be checking the actual charge rate with a multimeter), I thought I should check in here to see if the Z4 has some quirky issue other than a failing alternator that causes the charge indicator light to come on and off,....intermittently.
