Installed some LED strips in the boot of the ///MR
Tcochrane92
 Leamington Spa, Warwickshire, UK
One of my Xmas projects for the M roadster was to improve the dreadful lighting in the boot.
Installed some of these:
https://m.ebay.co.uk/itm/5050-LED-Strip-Light-12V-Car-Caravan-White-Blue-Red-Green-Warm-White-10-30-cm-/262453353235?varId=561256772545&txnId=2139740736016
Tapped into the original bulb wiring and ran the cables at the top, you can see them in one of the pics. All soldered and heat shrinked neatly, wires hidden
I think it works quite well :thumbsup:
The LEDs are a vast improvement and an easy mod. If you haven't replaced your interior ones you should as these are an easy mod too :thumbsup:
I intend to install small LED strips in the footwells too :)
Scooba_Steve said:
MrPT said:
I need to do this. Good mod.
I'll be making up some kits again in the next few weeks. Connector mates with the boot light, same shape as the one on the lens cover.
That would be far easier than what I did :P
