Hi all,
I recently bought a silver cable from BCables (K-Line and D-CAN capable) to try and bleed my brakes properly by activating the DSC pump (pedal is not as firm as it should be).
I managed to successfully install INPA, DIS, etc., and communicate with the car, however, I cannot access the DSC module within INPA. I get the following error with different versions of INPA (5.0.2 and 5.0.6):
I checked the scripts I have and indeed I don't have 'DSC_85'. I was wondering if anyone has successfully communicated with the ABS module and if they could send me the scripts they have (all the research I did suggests that's my problem).
Extra info:
Requested control unit: 'DSC_MK60' not found. Control unit found: 'DSC_85'. Program will be stopped.
Extra info:
- I installed Mike's Easy BMW Tools (INPA 5.0.6) and also installed INPA 5.0.2 manually from the E9x forums. I get the same errors with either one.
- My E86 is a 2008 and it seems it still uses K-Line protocol, as when I'm in D-CAN it cannot communicate with any modules.
- I don't mind paying £15 to buy the one-click install software from Bcables if they have all the right scripts.
