First things first..Is your battery ok?
mr.tourette said:First things first..Is your battery ok?
Jfgoldfish said:I didn't know E85s had angel eyes.
Which generation/model had them fitted?
BlastDK said:mr.tourette said:First things first..Is your battery ok?
Actually, when this issue drained my battery and I recharged it. It took days for the triggle charger to get the battery to show charged. Could be that the battery is not working well?
As Mr T said, I would suspect the battery. My 2007 car was still on its original battery when the car seemed to become posessed last June - headlights coming on in the middle of the night was the most spooky. I changed it for a new one from Halfords (Yuasa YBX5110, £132 inc. fitting) and it solved all the electrical gremlins. Sometimes the battery will have a small, round window in it which, depending on the colour showing, will tell you if your battery needs changing.mr.tourette said:BlastDK said:mr.tourette said:First things first..Is your battery ok?
Its possible these cars are extremely sensitive to weak batteries and can throw up a myriad of faults if they're past their best.. do you have date stamp on the terminals and have you checked it on a multimeter after a charge. Not saying this is your issue but its always the first place to start if you have more than one electrical gremlin
