So the bulb warning light came on yesterday and it appears the left indicators bulbs are the issue. The bulbs are lit all the time - they still flash as normal when I indicate left but stay on when I turn the indicator off. Clearly a fault somewhere.
I don’t know whether the solution is to change them, or if it’s caused by another problem. I did change the headlight bulbs 8 weeks ago.. not sure if this could’ve triggered a problem.
Anyone had this / can recommend a fix?
