Indicator Lights on dash not working
mrblake1
 Cardiff
Hi
A bit of a strange one here.
The Indicator lights are working perfectly on the outside of the car.
However, the dash board is not showing the direction indicators. it's the same for the hazard lights too.
Also the radio has a mind of it's own. Sometimes it comes on but i can't adjust the volume or change the channel or input.
Has anyone had this before?
Hi all,
After some electrical assistance? As per the above, one of a few faults. The car has been parked up for a while, outdoors. And has suffered a bit with water in the passenger footwell, and boot. The car is facing up hill so water is at the back of the well. The boot I have found 3rd bake light 😡 the other could be door membrane?
Anyway, the other day wife came home and the alarm was going off, no attempted breakin etc. the batter had gone flat, but is on a cteh (off at the time) been recharging since Monday, good enough now to start the car.
But, I have now picked up a few electrical gremlins :headbang:
- C110 fails to read modules,
- the radio, does come on
-Indicators flash but no dash indication
-No fog light indication on dash
- no headlight high beam indicator
- roof won’t open nothing , lights windows or unlatch
I now over the cold period the Z had a lot of internal condensation, due to the water ingress. Which I’ve tried to keep to a minimum. And up to last week all worked fine. Odd now the car is drier, and it’s not so cold.
As mentioned car starts fine, heater, heated seats, lights, steering, power seats all work fine. Check a lot of fuses but no joy.
Any direction would be a great help 🤞
A recent thread from another owner (iamorion) found similar issues caused by dash issues in the cluster
I’d await an update from him?
. Thanks bigwinn :thumbsup:
Hi there. I have the exact same issues with mine after leaving it out in a rain shower with the roof down. Did you find the solution by any chance?
