J JDSZED Member Aug 4, 2016 #1 Hi all Recently noticed one indicator flashing much quicker than the other, with the light on the dash doing the same Anyone else had similar issues... Faulty connection I'm guessing? Any help appreciated Cheers
M mattyp Member Beckenham, Kent Aug 4, 2016 #2 I thought that indicated a bulb had blown? have u checked they all flash?
A Anonymous Guest Aug 4, 2016 #3 Normally this is a signal that a bulb has blown in that sides lights . Check you bulbs are all working including the repeaters on the side
8 85genius Senior member Aug 4, 2016 #4 If not a blown bulb could also be your battery is on its way out, that was one of the many gremlins I had that were all fixed by replacing the battery
M Marlon Lifer Lancs. Aug 4, 2016 #5 Each indicator has 2 bulbs - it could be that one has blown, thats what happened to me :wink:
S Scooba_Steve Elite NW London & Somerset Aug 5, 2016 #6 Wouldn't you get bulb out warning? Or are indicators not monitored?
M Marlon Lifer Lancs. Aug 5, 2016 #7 Scooba_Steve said: Wouldn't you get bulb out warning? Or are indicators not monitored? Click to expand... Yes you would get a bulb warning light (its not clear if that's what the OP is getting)
