Incase of puncture??
jayd1000
Hi guys as my zed is running non rft's what's the score if you have a flat?? Repair kits or spare wheel and jack in boot??
Cheers jason
You should have a proper BMW emergency pack should you not? If not, stick a can of gunge in the boot but these are only good enough for a pin prick puncture nothing else.
The Z4's boot is surprisingly large so a spare or space saver would fit.
Lastly, join one of the emergency outfits & get them to rescue you if & when needed.
Sorry, can't be any more helpful than the above.
In the boot of my Zed there resides the following:-.
Lock nut.
Wheel Brace
Wheel Jack
Puncher Repair Kit
Compressor
If it's just a nail then you can fix it side of road a drive on. :thumbsup: :D
Can of instant fix glue (Wrecks your tyre), but you can drive to the garage and get a new one. :)
In my pocket I have:-
Britannia rescue card.
Mobile Phone.
These I used when my tyre blew big time this summer. Took two weeks to get a new PSS delivered from Holland and fitted locally. Missed the SW run. :cry:
The following are necessary and take up almost no space in the car: Cell phone, credit card, auto club membership. I do have a tiny 12V air compressor as well. I am still running RunFlats, but intend to switch to conventional tyres next spring.
David
Couple of these babies in the boot (plus AA membership) :
EDIT - and a mini compressor
http://www.halfords.com/workshop-tools/garage-equipment/breakdown-essentials/holts-tyreweld-500ml
I keep slime in the boot as recommended on here when I asked and allegedly it doesn't kill the tyre. Its pretty cheap from ECP (£24.99) plus I have my trusty AA card :thumbsup:
http://www.eurocarparts.com/ecp/p/car-accessories/car-accessories-products/emergency-and-breakdown/tyre-foam/?539771440&&cc5_906
That's the same one I have. Which I believe is one use and new tyre needed. But better than Nout. :wink:
http://www.ebay.co.uk/itm/Tubeless-Tyre-Repair-Kit-Car-Van-Vehicle-Wheel-Tyres-Puncture-Hand-Tools-Case-UK-/282173127205?hash=item41b2d43a25
Above Link is the repair kit I have. Never used it but the instructions are straight forward. :thumbsup:
Lock nut.
Wheel Brace
Wheel Jack
Puncher Repair Kit
Compressor
Mobile Phone.
Do you get yours repaired here ?
greg1953 said:
buzyg said:
In the boot of my Zed there resides....
good first post greg, i'm a stickler for spurious spelling too :thumbsup:
now, as forum decorum dictates, let's see an equally impressive introduction to you and your zed please......
:wink:
I have this in all car tyres. It protects against punctures through screws, nails etc. It won't protect against a sidewall blowout but gives peace of mind that small punctures are handled. As a bonus it's water-based (so easily washed out if you need to switch wheels), seals small leaks and apparently also conditions the tyres (although I'm sceptical on the last one...)
I also have a continental tyre compressor and sealant as backup... belt & braces approach.
greg1953 said:
Lock nut.
Wheel Brace
Wheel Jack
Puncher Repair Kit
Compressor
Mobile Phone.
Not repaired no. Wouldn't let an out fit like that fix my tyre. That's where I buy my new ones. :? :wink:
