In need of a left b pillar satalite
Stodge
In need of a b pillar satalite. For a 2003 e85 if anyone has one. I have fault code 0093bb. Is it a case of swapping the unit across or does it need any coding ?
You need to get the part number of your existing one as they are not all compatible. Many before you have simply bought one from eBay only to find it won't match their car, and they are not cheap!
Grab that part number and post it on here and we can let you know which batch you can select from.
Once fitted it will need to be coded with the VIN and the System Time.
Many garages will confidently tell you they can do this, but I've yet to find one that can. May sound daft but I believe their software is too new.
You need INPA, WinKFP, NCS Expert and ToolSet32.
If you have this and are able to use it then there is a guide on here somewhere.
If not, let us know whereabouts you are and hopefully someone can assist.
But do get the correct part first.
