Improving Harmon Kardon sound quality
Swiftly
Since I first bought my M40i, I´ve struggled to improve the sound quality that the Harmon Kardon unit produces. Compared to the HK set-up and sound quality produced in my previous M240i, the G29 setup is very disappointing and just lacks any depth or detail. Today, I decided to code the Bowers & Wilkins sound settings using Bimmercode, which extends the sound presets that are activated in the settings in the iDrive system under “Sound“. All I can say is wow, the more I listen the more detail I hear! I now have 5 presets to choose from, Studio, Concert Hall, Stage, Cinema and lounge, with a noticeable difference being heard between each of the presets. I just wish I had opted to code this sooner.
Ah, need to have a look and see if I can work it out, I'm not going near expert mode either. :rofl:
Can you remember the steps?
In Bimmercode go to Audio, and select Bowers & Wilkins, and code, that is it plus it only took about 1 min :thumbsup:
Well for some strange reason my Bimmercode will not connect, was fine last week and ethernet connection is showing on phone but it does not want to play.
Is it that big a difference?
I never found the sound lacking. I’m be interested to try it although I don’t have binmercode….only Carly.
Argyll Andy said:
Nick, good to know :thumbsup:
Do you by any chance know if this sound menu can be accessed via Carly or does it have to be Bimmercode?
For a small fee someone with Bimmergeeks Protool could toggle it… :rofl:
Although if I’ve followed it correctly it’s a frig..ie you are using the device settings for a different make of hardware than you should? :tumbleweed:
Not that there isn’t necessarily anything wrong with that…maybe…
I only came across this coding on another forum, it would seem that this coding option is also available for other BMW models and looking at the posts going back a number of months, they all seem positive. Either way, it can be quickly restored to the original version.
It’s not unusual for the geeks, be they coders or owners to find these options and probably in the case of an audio system unlikely to do any damage..
You can do the same on the E89 too…albeit much more limited..
As you said Peter, I doubt it would do any damage as the coding only replaces the stock HK 408 Watt Logic 7 DSP amplifier preset with the Bowers & Wilkins 5 presets:
Studio - No surround, just music as recorded (claims)
Concert - surround dsp emulates a live concert hall
Stage - surround dsp emulates live stage
Movies - surround dsp emulates movie theater
Lounge - DSP applied to rear speakers
For me, Concert, Stage and Movies all sound very similar, with Concert perhaps the most balanced and clearest. Stage and Movies have some enhanced base and a more muted upper end.
I’m just surprised that the software for the B+W which was destined for what I assume was a much more capable system works on what appears to be a successor to the mid-fi E89 system aka HK….. :tumbleweed:
I assume it’s a thin veneer of application software ..
Whatever if it works for you and others great :roll:
I’ll have to listen to Andy’s system once he stops playing The Monkees..
So the HK sounds like it’s a 7 or 8 channel system ?
It's a 7 channel system
:thumbsup:
