Don't think I made my post to clearBeedub said:i ususally change up @ 7900-7950..... that s54 was designed to rev!!!!
i try to avoid clipping the softcut limiterhowever.. sometimes its unavoidable however to the speed in which the revs rise.........
2dogs said:Don't think I made my post to clearBeedub said:i ususally change up @ 7900-7950..... that s54 was designed to rev!!!!
i try to avoid clipping the softcut limiterhowever.. sometimes its unavoidable however to the speed in which the revs rise.........![]()
I was thinking more of a daily small hoon not an out right red line
I.e.: would you shift between 2000-4000 or may be 3000-5000 that sort of thing
I shift up about 3500-4000 is this too soon?
So it would look like i shift way too earlyBeedub said:2dogs said:Don't think I made my post to clearBeedub said:i ususally change up @ 7900-7950..... that s54 was designed to rev!!!!
arhh ok, on a light drive ill change up @ 4500-5500, see my original post, now edited![]()
Sorry BMWZ4MC miss your post! so 4500-5000 would be about right,BMWZ4MC said:Max torque is around 5,000 rpm, so in theory keeping the revs around that level should give maximum acceleration. However, the torque curve is pretty flat throughout the rev range. This means that when accelerating from rest to a given speed, the potential gains from changing up appropriately to keep the engine around 5,000 are easily offset by the time saved through reducing the number of upshifts required if the engine is allowed to rev to the red line.
Of course, changing up early also denies you the opportunity to enjoy the full glory of the screaming animal under the bonnet :evil:
I'd say, shift up at the red line (but before the limiter kicks in) when accelerating, but try to exit corners in an appropriate gear to start that acceleration from around 4,500-5,000 rpm.
alfamale said:The point of reving high is to make sure the engine is still spinning in the optimum HP and torque band after its lost momentum during the gear change, it seems a bit pointless to own an M car and granny shift all it's life
original guvnor said:alfamale said:The point of reving high is to make sure the engine is still spinning in the optimum HP and torque band after its lost momentum during the gear change, it seems a bit pointless to own an M car and granny shift all it's life
+1
I actually don't think it's healthy for an M to be driven almost exclusively at low revs. As I think Beedub said, these engines are designed to be revved. They didn't set maximum power at 7,900 rpm for no reason.![]()
milu said:Never redlined mine......been close though on a few occasions.
I generally change up before 4k I reckon,only winding past this relatively infrequently.
Exactly my problem as well....well there are exceptions....Wondermike said:If you don't use all the revs you're missing the fun of the car. The only issue is the gearing, for me it's still too tall. Over 100mph in 3rd really only leaves 2nd for red lining.
toplad said:milu said:Never redlined mine......been close though on a few occasions.
What a waste
