How to turn up sat nav volume?
sunnydays
Hey guys,
Does anyone know if there is a seperate menu where sat nav volume can be turned up? I often find with the roof down it is hard to hear, especially with music playing. I can usually only adjust the sat nav volume when it is speaking, by rotating the volume nob. Surely there is a seperate menu for this?
Is there a button to get it to repeat the last instructions too?
As far as I know the only way to adjust the sat nav volume is when it is giving instructions, I can’t help with repeating the instructions.
As far as I know once it's spoken that's it, no button to repeat. And your right about the volume, that can only be set when it is speaking.
Not sure if it is the same on a Z4, but my 335 sat nav will give instructions if I hit the 'Map' button when it is already on the map and navigating.
I usually have the spoken instructions turned off and just hit it if I need confirmation.
I think if you toggle spoken instructions off/on it might repeat. I generally drive with it off anyway. Afaik the only way to adjust volume is while it’s saying something.
