How To- Retrofit Electric/Heated seats
bigwinn
Hi all
I wanted to upgrade the seating in my E85- I'd searched everywhere and found a lot of threads around how to- thought I'd write mine up here if it helps someone in future...
First off- I'd rate this 3/5 on the difficulty scale, however I made some of my own cockups so all in all its not too bad! I'd done this before on an E30 and that was more complex- needing to install looms, relays and fuses etc.
As far as I can gather this is fairly easy on E85's build date to Oct 2004. Mine being Jan 04 I took a punt and all the loom etc was in the car already.
Shopping list was fairly short:
1) set of seats, heated or heated+electric
2) heated seat switches
Having procured both- I did some research and decided to crack on.
I'd say there are 3 stages to retrofit:
1) old seats out
2) old seat parts to new seats (if needed)
3) install new seats and buttons
Before you do anything- disconnect the battery for 20-30 mins to avoid airbag lights etc.
1) Old seats out:
Fairly simple, there are 4x 17mm bolts per seat, simply pop the front bolt covers off and undo all 4. Then undo the lower seatbelt bolt, again 17mm, the small torx holding the seatbelt guide on the shoulder so that slips out and you are ready to go under the seat to unclip the harness. IMG_7466.jpeg
The harness unclips the OTHER end of where the screwdriver is, and pulls away from you allowing the plug to slide out.
Then your seat is free. Take it away (be careful as they are big, bulky and scratch stuff for fun) and hoover the car out once you have done the other side.
2) Old seats parts to new seats
Note that I needed to do this as my new seats did not come with seatbelts, sensors and yellow plugs. If yours do- jump to reinstall new seats!
Slight difference between passenger and driver seat, but principle is the same. You are disconnecting the seat belt clip and associated loom back to the female part of the yellow plug. On the passenger seat you will also unclip and take off the seat sensor.
Passenger:
undo the seat occupancy sensor
Twist the sensor off the seat
Unclip the female yellow plug- note there is a black 'cable stay' that slides off which keeps all wires in place too
Undo the seatbelt clip and this is what comes away from the seat!
On your new seat- start by reattaching the seatbelt clip to the seat. Then run the wiring through the right route away from moving parts to reattach the seat sensor, all in reverse to taking it off.
If you then reattach the female yellow clip (or do this once the plug is reassembled) to the seat you now need to insert all other seat plugs- these are just a game of right male into right hole- you'll see what I mean, but you end up with a new female clip looking like this:
Then slide the black securing sleeve in place to stop the plugs slipping out (which again they do for fun)
That is a seat ready to reinstall!
Drivers is very similar albeit omit the seat occupancy sensor
OK so really this is easy- but a few watch outs. Reconnect the seats to the car via the looms- opposite of the unclip- the securing clip holds it in place. The reason for reattaching looms is that you will need electrics to move the seats to rebolt them.
Open the ashtray- pull the insert out- undo the single cross head screw and pull the ashtray and old switches out- fairly simple once you know how. Undo 3x loom connections, unscrew the switch panel (x3 torx) and pull the old switches away. Reinstall the new switches, re connect loom, pop the switches and ashtray back in and screw in place.
Now connect the battery.
You should now be able to bolt your seats back in place- 4x 17mm to floor, 1x 17mm seat belt anchor and small torx screw to rescuer shoulder belt guide on seat.
And that's it.
Credit where its due to:
@Left98204- sage advice thank you
@Mac27040- again great guidance thank you
@Parabolica- Marc thanks for the seats, top man for arranging them all the way from way up north!
Also the guys who helped with seatbelt guidance when I got stuck
Stuart
Nice write up, thanks.
I have a 2003 Roadster and I’m about to fit aftermarket heated pads to my seats. Will they work if I wired them into the loom and fitted the factory heated seat switches? This would save a a couple of hundred pounds.
Mike
Hi Mike
In theory yes
Your 2003 car has the loom in place so + and - connected to the aftermarket pads will work ok
You may need to fool the thermistor into thinking it’s doing a job- which may need sorting
And it’s not the easiest job to fit pads to standard seats, sports seats are much easier
Is the thermistor already in the circuit? Or is it part of the factory heated seat? I see a variable resistor in the circuit diagram.
The thermistor is in the seats with the heating elements fitted
You may need to take the feed wire from the plug, pass it through a thermistor to earth
Otherwise I think the seats will not fire up
Easiest option (knowing you have an 03 car) is fit seats with factory elements. They are just plug and play
Hi. A question about the occupancy sensor... I've sourced heated electric memory sport seats to install in my 2006 3.0Si SE. There are no switches for heated seats and the old seats were, obvs. not heated.
I can't work out whether I need to check whether my old seat had an occupancy sensor and whether I need it on the new seats, or just the passenger seat? I'm not quite following why both new and old seats wouldn't both have occupancy sensors fitted?
Your new seats should have occupancy sensor on the passenger side only
If you are putting facelift seats into a facelift car and assuming nothing has been taken off it should be like for like
Older pre facelift seats have a black box a bit smaller than a deck of cards underneath the passenger. Facelift seats don't have the black box.
Thank you. I’m not sure if the new seats are pre or post facelift. They’re in the car so not easy to inspect. The old seats are post facelift, so I’m interpreting they don’t have a black box I can remove in any case? I’m assuming I can source whatever I need if it turns out the new seats are missing the sensor.
We're your old seats electric?
You have stated they were not heated, your car does not have the wiring in place for heated seats. You'll need to add the wiring as well as fitting the heated switch buttons near the ash tray.
If your old seats were not electric then you'll also need to the wiring for that as well.
This is all possible to add yourself if you are willing to put the time in and are happy to remove a few interior parts around the drivers and passenger footwell and remove the glovebox for access to the fusebox.
Seat occupancy sensors are possible to find second hand but for the M-sport style seats they are harder to find.
The old seats were electric with memory. Just not heated. I’m half hoping I might find wiring in the centre console but realise it’s unlikely given it’s a post facelift car. The new seats are electric, memory and heated, so I do want to enable the electric.
You'll be very very lucky to find the wiring there for the heated seats. The only way it could be there is if a build was specified by a customer and then they cancelled the order partway through the build and then the chassis used for another customers build.
Yes... I'm expecting to have to source the necessary wiring and get busy taking the car apart to fit it... I've yet to work out exactly what I need.
I have ordered a replacement seat for my car, as the old one was terrible, and the new one has the heating element installed. How can I tell if the car has the wiring for the heated seats preinstalled so that I can complete the retrofit in the future?
Whatage is the car? It will only have the loom in place before October 2004
hisXLNC said:
Car is late 2006 facelifted model. 2.0 engine.
Thst should answer your question then. :thumbsup:
That is if we assume your seats are the originals. If by some remote chance someone swapped out heated seats then you're in luck..................... but realistically not much chance of that.
Top
