How to remove the rear plastic trim panels behind seats?
d3matt
 Oxfordshire, UK
I need to remove this plastic panel to gain access to the roof control module connectors (following a failed SmartTop install).
I've unclipped it from around the door seal and removed the screws behind the storage box, but it looks like I also need to remove the rollover hoop and the centre console area as it goes beneath this. Can anyone give me any pointers how to do this as I'm stuck and don't want to damage anything.
Hey, was there any info on this? I am in the same situation but with an e86 2008. The plastic bits are all smashed from excessive heat and the seats hitting them. I am thinking to remove them and if I cannot find replacements then maybe covering whatever is under the panels with alcantara.
You have to take the rest center console out and the upper plastic piece behind the roll bar and then you will find two screws holding it on. You won't be able to cover the structure underneath.
