How to remove cd changer in E85
Do you mean the one in the centre storage?
If so, simply remove the centre console from behind the handbrake, up to the top (plenty of guides on here)
Then you have room to reach in to it.
Best method is to undo as many of the mounting bracket bolts as you can, giving wriggle room to get it out.
Unless you are intending to fit another one then you will need the lower storage cubby. They simply push fit into place once the mounting brackets are all removed.
Are you about to do a write up or are you asking for help? If its the latter then try the search as its likely been discussed a few times before.
Many thanks to answers, I'm asking for help but it looks as if that now has been provided on this thread.
Halfway down this thread, Wassup seems to have found a fast way to remove the changer…
https://z4-forum.com/forum/viewtopic.php?p=1917340&hilit=Remove+cd+changer#p1917340
