How to chek if rims fit your car
ZetaTre
 San Diego County
I've been looking around for some time of a good resource to figure out what wheels will fit. Too many variables to consider:
1) will the offset fit my car?
2) will the tire fit the rim?
3) will my speedometer reading be all screwed up?
4) will the rims be rubbing?
5) <add yours here>?
I found a couple very useful resources I though I would share
LINK #1 tells you how the diameter/speedometer reading of different tires compares to a standard.
LINK #2 gives you detailed dimensions of the wheel compared to a standard. It gives measures of suspension, fender and wheelwells clearance. And also tells you the rim size that a particular tire size will fit on.
It would be great to find a resource that tells you what tire size would fit on a particular rim size. If anyone has it, it would be great if he/she could share it.
In addition to Zeta's links, here are a few more.
Wheel Offset Calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
Tire Size Calculator:
http://www.1010tires.com/TireSizeCalculator.asp
More links:
http://www.alloywheels.com/tyrecalc.asp
http://www.miata.net/garage/tirecalc.html
I've always found this site a good source of information on wheels and tyres.
http://www.carbibles.com/tyre_bible.html
More links:
Great links and help - thanks! Now to just find the funds.
Thanks again for all of the welcomes.
