FD3S said:Rombbb said:FD3S said:The only way I know that you can see for sure if the car has a program is to copy the program with the right software and usb cable and compare it with a stock program for Z4M. Only your mechanic can do that and even him maybe be able to do not do it. The simple way would be to try going at higher revs (some programs remain at the same revs as stock), the sport button (some programs use the on off button like the stock), and the speed limit.
Seller said that limiter was removed, just wonder if more was tweaked that might impact the cc. I will research and try to get software. Agree with you that its probably the best way. Intend on keeping the car for long so getting a bit handy with the software wont hurt. Want to be able to read error codes as well instead of paying big bucks for 5 min of work
I can feel you. When I bought the car I was super excited about it. Be careful about the software since not all the softwares can read the all the error codes successfully. Even if the software that you buy can read the error codes, you need a software which can "copy" the software from the ECU and then be able to open it, read it and compare it with a stock file. I believe that you will waste your money on that procedure. Just my 2 cents.
Thanks, good point
