Check the oil level a couple of times before you top up ..sometimes it reads low..if you then put a full litre in then you get the over full message which is not good on these engines…
Personally I put half a litre in and check then puts bit more info required..
Normally N20 engines 18i 20 28i don’t burn oil between services so a litre for those is quite a lot..
