E Easty-5 Member Aberdeen Aug 3, 2014 #1 Car is going in for it's inspection II on Wednesday and I said I would supply the brake fluid. Going for Castrol SRF. Stupidly expensive but have heard it's by far and away the best available. Will 1L be enough for a fluid change?
H hopz121 Lifer Guildford Surrey Aug 6, 2014 #2 I would get over a litre to be in the safe side also you can then re use it when you do you next brake fluid change.
S swanicyouth Member Aug 7, 2014 #3 If your flushing out the system completely it takes under 2L or so. I always buy 3 just in case.
