How do you remove the side light at he top of the front bumper??
Bluecat
As per the topic this is the plastic rectangularish lens on the top side of the front bumper is there a way of removing this to clean the inside??
The white reflector on facelift E85 and all E86 Zeds has two threaded studs on the back with pressed steel nuts holding it into the bumper skin. Not sure if you’ll be able to take it off without removing the bumper first, but suggest you take off the upper inspection cover from the wheel arch liner first to see if there is access to it beside the back of the headlight.
Chris
I’d unclip the bumper. I think you’ll have to anyway, but even if you can get your hand in there chances are you’d drop something and have to take it off anyway.
Good excuse to give it a quick spruce up behind the bumper too :)
