How do you remove the exhaust tail pipes?
Jimmy Gee
 Midlands
Ive located the screws underneath that look like a type of grub screw with an internal thread but how do you remove them?
Perhaps they were just pushed on because they are a tight fit.
I fitted some to mine a couple of weeks ago and they were tightened with a philips screw.
I tightened them as far as possible and the screw heads are still proud of the pipes.
I just removed mine yesterday. The ones on the 3.0si coupe are simply held on by tension clips so its just a case of twisting and pulling to work them free. They then just slot back on in the same manner.
Makes them very easy to clean!
I will have to have a go at that, sounds like that could be it. Although you have a later model than me so they could have changed it.
