Chris_D said:
Excellent write-up kis and I'm sure this will help others too, maybe including myself - I'm thinking about adding extra insulation (2mm adhesive mat) between the top shell and lining for even more of a cosy,quiet feel
I'd expect it to be made of GRP or some other rigid polymer material although I initially thought it was a thin steel panel due to the sheer weight of it.
Did you have any problems with the extra insulation affecting the fit of the liner shell and hard top?
A felt pad may be better for weight, wear and compresability by the liner shell. Just like the old days: https://www.thefeltcompany.com/eco-felt/.
Noise levels will also be reduced using the outside side covers installed under the hard top.
My hard top is a polymer material. The front corners were damaged by storing the hard top glass up, by a previous owner, and no metal was imbedded there. The glass rear window is perhaps the heaviest part of the top.
