How do you clean yours?
WizzEssex
 Essex
Hi guys- can any one advise on best way to cleans the 'bolts and bolt-holes' on my split rims- 108's. The bolts are stainless but they seem to be crap-traps for all the road muck and brake dust! (I did sort of expect this a little)
I'm currently using a paint brush that I 'wiggle' around in there but noticed many of the 'wheel- clean' products say not for use on split rims.
How do you clean yours ?
Don't have 108's - have Dynamics and they are a pain to keep clean. I use Bilberry and a wheel brush, agitate, rinse and all clean. I also use Rimwax (few coats applied at least once a year, usually in spring and autumn) as it keeps brake dust from bonding to the wheel
This works quite well....
Old toothbrush - the bristles get right inside the hole and down the sides. I use PH neutral wheel cleaner too.
I must be lazy as I just use the Karcher held at a reasonable distance.
This takes most of the crap off ready for a quick once over with a cloth
+1 - at the moment
However, once my new 108s arrive I will be turning over a new leaf. Poorboys wheel sealant and brush will be bought. I have Turtle Wax Platinum Wheel Cleaner, which gets rid of most muck. Only thing is, you need to re-seal your wheels after use to stop more muck sticking to the wheels
Most of you are missing the point :poke:
It's the small screws that hold the two parts together the OP is talking about.
I used one of these when I had my 108's
http://www.lakeland.co.uk/21572/SonicScrubber-Bathroom-Brush
I didn't miss the point... however I thought my neighbours must think me overwhelmed by OCD, but this takes it to a whole new level !
(think I may get one...)
You can get the Pro Detailer version at Halfords for £14.99. You can get additional brushes as well.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_700729_langId_-1_categoryId_255232
Sent from my iPad using Tapatalk HD
I found the oral b vitality toothbrush was perfect for the job. A bit expensive perhaps of you were to buy a new one but if you can get your hands on an unused one they're perfect.
I can also recommend Bilberry Wheel Cleaner. I just bought some more from cleanyourcar.com
