E exdos Veteran Sep 28, 2012 #21 The OBC will use exactly the same numbers that the ECU will use for the correct fuelling, so it won't be far out. It sounds like you do quite a lot of driving with a cold engine and in low gears, all of which produce low mpg figures.
B bluestreak56 Veteran Maidenhead Sep 28, 2012 #22 Even less than a mile and it sounds like you're doing well. 4 miles I'd expect a tad more but not much.
