Horrible suspension noise
Limonge
Hello buddies,
I've noticed a horrible suspension noise, which comes from the front axle. From what I've seen it only occurs when the brakes are not pressed, if I press them the noise stops completely. Do you know what could it be? I recorded a video so you can check it out
[youtube]6TvY_sLrIbA[/youtube]
You made left turns on a bumpy surface...
Does the noise change when turning right, applying brakes, only over bumps?
Here a few things I would start with...
carefully inspected the brake calipers?
Inspect brake shield?
Checked the wheel bearings?
Jack up car and manually turn and move each wheel?
Check for loose or missing bolts on the reinforcement plate as well as transmission air duct plate?
Or just avoid that noisy cobble stone section of roadway :rofl:
Hello, I chose that bumpy surface to clearly show the problem, but it happens everywhere... It appears when going straight, turning left/right, in every condition except when braking (in the video there's a moment which it does not make noise, I was braking)
I'll take a look under tomorrow, I hope I'll see something loose...
