grdz4roadster said:
When I pull the hood latch, only the driver's side of the hood unlatches and I can't open the hood. It has been very cold the past few days, but it can't be frozen as the car has not been washed or wet for several weeks now. Any ideas?
:scratchhead: I thought only the M had dual latches.
... I had a problem with mine one time.
Pull the lever & it just wouldn't pop open.
It was recommended by someone else that had the problem, to just pull really hard until it releases.
I pulled the lever to the point I thought it might break... & then it popped open. (figured if it broke it would be warranty)
In my case it was after I closed the hood gently by letting it down slowly & pushed down to latch.
Since that time I let it drop closed from about 6 - 8".... & no more problem.
I haven't tried to duplicate since, but I suspect that the gentle close didn't fully set the latch;
which made it harder to open.
On an older car, it could obviously be a cable problem or lack of lubrication.
