Tonytopdown
Hi all, can anyone kindly assist?
After 10 years owning my E85 roadster I finally got round to relocating the roof motor. This due to retirement, and fine weather. I might add - what a job that was. I filled up with tears once the motor and housing finally flopped out into the boot. Anyway, everything back together and problem. Hood down button, retracts as it should and locks into place. Hood up button, the windows drop then flashing red light and everything stops. I can leave for a while then the flashing stops, try again and there is a low sort of ping sound from both up and down buttons. I finally manually unlocked it, tried again with both buttons and it did close. It did this pattern three times. Motor and hydraulis seem fine but something clearly not right.
Only sensor I believe I knowingly touched was the parcel shelf. Everything worked before.
Any support or guidance anyone can give would be very much appreciated
Many thanks in advance for your help
Tonytopdown (like to be tonytopup)
