Huzee4 Senior member South Wales Mar 27, 2021 #1 Dear all, I’ve convinced myself there is a rattle or vibration coming from the speaker pictured, I want to take the housing off to investigate however I’m worried about causing damage. Any advice would be appreciated Attachments 86A90F18-45C8-44DC-8066-12A67229B7A9.jpeg 185.9 KB · Views: 452
A Anonymous Guest Mar 27, 2021 #2 It’s just a snap fit like so many E89 trim parts. There are two tangs cross shaped that locate it in the door pillar metalwork.. The tweeter if fitted us glued in place with a couple of dobs of glue.. A trim tool should help you plop it out.
Huzee4 Senior member South Wales Mar 27, 2021 #3 Pbondar said: It’s just a snap fit like so many E89 trim parts. There are two tangs cross shaped that locate it in the door pillar metalwork.. The tweeter if fitted us glued in place with a couple of dobs of glue.. A trim tool should help you plop it out. Click to expand... Thank you I’ll give it a go
