Watson1911
Good afternoon everyone.
As of Sunday I am now a Z4 Coupe owner
Some of you assisted with some thoughts on the car before I purchased so thanks to those that gave some input/advice.
Here is a photo of the car
I have pulled together a 'to do' list of things I want to work through. Initially it would be great for some input and help with the following please (note: I am not mechanically minded and haven't grown up around anyone who is so very new to hunting down parts and understanding this kind of thing so please give it to me in layman's terms :roll
1. Seat colour restorer. See below interior photo. VIN decoder says the interior is "New England"/estoril-blue, now having seen a lot of estoril blue cars on the road, the interior doesn't look that bright. Does anyone have any experience of this blue and colour restoring so I order the right colour?
2. Original grill with chrome surround and graphite slats. I don't like the black grill it came with and want to swap it out for a OEM factory appearance. Where is best to get one please? (or does anyone fancy a swap?)
3. Fog light replacement. One has been swapped and looks fine. One is heavily corroded. Where is best for a replacement please?
4. Drivers window is quite heavily scratched from presumably a corroded/dirty window seal. Other than a second hand window from e-bay any other options? Also, where would I get replacement window seals? I would look to do both sides.
5. Water pump replacement. There are no records that this has been done to the car and the mileage is 89k so I will be looking to swap out sooner rather than later. From things I have read Pierburg seems to be the one to get? and seemingly I should be doing the thermostat and coolant at the same time?) Links to those items would be appreciated.
6. Handbrake not holding. I will get a mechanic to take a look at this (loose cable / ratchet gone)
7. Preventative maintenance. Anything else I should be prioritising/carrying out?
- rocker gasket cover?
- oil cooler gasket cover?
- gearbox oil (do people do this or leave alone?)
- vanos solenoid?
- drive belt?
8. I am ordering new tyres all round and going non-run flats. Is there anything else suspension set up wise worth doing to really improve the ride and feel?
Thanks in advance.
Matt
- vanos solenoid?
- drive belt?
Thanks in advance.
Matt
