Help with codes - updated
Dr. Zed
 Swindon
I don't have any lights on the dash right now, just FYI.
Update/edit: so I stupidly ran the reader and panicked and posted a bunch of codes here without first clearing them and then seeing which ones came back. This is the updated list of the ones that came back after someone here pointed out my very rookie error. (thanks enuff zed. Really should have done this!)
Of the 17, only 3 have stayed. Any help appreciated!
Central Chassis Electronics Errors
Code: 00002A
Description: Short Circuit or line interior lighting. Central: relay remains at securing.
Code: 000048
Description: Wl1 line short-circuit to U-batt or wiper relay. Interior light line break.
My wipers sit slightly high on my windscreen (I have yet to clean the connectors to fix this), so it might be this but not sure.
Engine
Code: 0027C3
Description: CDKTOENS - error oil level sensor.
Wow that is a lot.
Is this after resetting and seeing which ones come back?
If not, some could be transient and you'll feel a lot better once they've been cleared.
enuff_zed said:
Wow that is a lot.
They haven't been cleared them. Rookie error really :headbang:
I'll try that and report back.
Lots of random voltage related codes typical of a bad battery state in the past maybe? Several look to be connected to the GM5 issue that you are aware of, and some may be down to dirty/faulty ABS sensor connections or ruluctor ring corrosion. See what pops up again once codes are cleared you might be lucky :thumbsup:
GM5 https://z4-forum.com/forum/viewtopic.php?t=102586
I'll need to clear them and see what comes back. To be honest, this is such an amateur mistake of mine...
Thanks for the guide. I have a guy on ebay that will do it but just haven't had the weather to be sat outside taking the module out.. :/
