My airbag warning light is illuminated and cannot be reset. I have an error code for a fault with the battery safety terminal (the pyrotechnic battery shut off device that is triggered by an impact).
Whilst investigating, I found that a wire has pulled out of a plug in a small cable that connects to the pyrotechnic charge. I presume this cable allows the SRS module to monitor the integrity of the battery safety terminal and perhaps even deploy the charge. The plug allows the BST to be disconnected from the car; the faulty wire has pulled out of the loom side of this plug.
As a result of a previous battery leak whilst my car was in transit from the UK to Australia, the plug has corroded and the two halves are inseparable. Damage from corrosion is also the likely the cause of the wire separating from the plug.
I’d be very grateful if someone could post a photograph of an intact plug and the wires either side of the plug please. The part is M-specific.
This is the cable in question:
The broken wire (red arrow) should be in the plug (green arrow):
This is my corroded plug:
Many thanks.
Many thanks.
