Help please -engine warning light [exhaust emissions value]
Scooba_Steve said:
If it's a sensor and it's plugged into the exhaust manifold pre- or post- cat then Lambda/O2 sensor they are essentially the same thing.
That's how I see it and why I suggested as a probable cause as they seem to fail quite often.
http://en.wikipedia.org/wiki/Oxygen_sensor
So its on the precat Lambda sensor -the NOX sensor is fine
Will know more on Monday when they re-run the diagnostics with new Lambda in situ
Apparently the BMW genuine part costs 250 and 150 is labour -which sounds OK
