Help! Error light causing problems
rajen44
Hey guys!
More a less at the same time I had my reversing parking sensor failing and an error light on the dashboard. I checked the reversing sensors and it sounded like it was the right sensor by putting in reverse and checking for the clicking sound. The error light is weird cos all the bulbs are working fine however, the right indicator is flashing faster than normal. Now I've got the drivers side of the window not going up in auto. It goes down in auto but not up in auto.
Any ideas???
Hi,
If the right indicator is flashing faster, then it's probably one of the right indicator bulbs , have a closer look, maybe remove and tap to see if the filament is broken.
Window, try doing a reset !
fixit man said:
Hi,
Hey,
I've checked the light without removing the caps, all indicator lights are lighting up, and I did the reset for the window but it now works sometimes? It's weird!
