Hi guys,
So, after washing my Z4 3.0si at the weekend I decided to drive it into the garage. While it was ticking over and I was checking my positioning I noticed a fairly loud rattling (hard to describe exactly) sound coming out from under the bonnet. I was pretty alarmed as it's not a sound I've heard before. I know people complain about the hydraulic valve tappets being a bit noisy when the oil has drained out of them but this was a different sound:
[youtube]HlQyvmHsQW0[/youtube]
I'm pretty keen to find out what's causing the rattling sound and get it fixed if I can. I initially thought it could be the water pump or alternator but I've done a bit of research and think it might be to do with DISA. So far I have:
- Disconnected the easy to reach DISA valve, no change in sound.
- Disconnected the difficult to reach (under the intake manifold) DISA valve, no change in sound.
- Removed the easy to reach DISA valve. Apart from a little oil, appeared clean with no play in the flap mechanism.
- Read the fault codes on the car. A few that were totally unrelated but an interesting one relating to the crankshaft position sensor.
- Started to try and remove the intake manifold to have a look at the other DISA valve, but then 1/3 of the way into the job realised how involved it is and called it a day.
Does anyone have any thoughts? Does it sound like a DISA issue or should I be looking elsewhere? Any suggestions are much appreciated!
