Heat shields and attachments
pvr
South East UK
Exploring under the car today to see what I need, and besides noticing a number of bolts missing that hold the heat shields, I also noticed that the rear shield over the exhaust is only attached at two points (bumper and one other place). What is the best approach to fix these back as they have either torn loose or rotted through at the bolt points?
The rear part is normally held up by the exhaust bracket by that has completely torn loose around that bracket. If I had some spare shield I could probably hold the rest up by putting a bolt through the middle of a new piece. Is that generally the way to fix that?
Anyone know how to remove the square plastic u cover that goes over the lower wishbone? I need to really treat those members to get the rust off but the plastic is in the way
Based on the similar ones on the E39/E53, I imagine the wishbone cover is just clipped on.
For heatshield repairs where its torn off the mountings I've used a baked bean tin lid as a 3" penny washer very successfully before now.
Thanks chaps, will have a go at pulling it off and start the cleaning project.
Good idea about the tin- with the amount of time I spend on the car that will soon be my dinners :D
