heads up bi-xenon clear headlights FS
powerontap
 Montreal
Ebay auction from Germany:
http://www.ebay.de/itm/BMW-Z4-E85-E86-Bi-Xenon-Scheinwerfer-Xenonscheinwerfer-Angel-Eyes-komplett-/140874270802?pt=DE_Autoteile&fits=Model%3AZ4%7CPlatform%3AE85&hash=item20ccc2c852
Please if anyone knows i need some info on these headlights.In case the halo rings die out they are replaceable?
I think youd have to open the light though?
I am watching these closely too probably loads of us bidding against each other hahahaha
VENDAR said:
Do i need different wiring to install them on my car or they are plug and play?
Regards
Plug and play if you have xenons already, if you have halogens, you'll need to recode but that's fairly easy to do.
Recode needed to remove bulb light out on dash.
Done with NCSexpert and lots of learning and needs a cable and a steep learning curve.
The pins of the headlight have to be moved as well.
On top of this the headlight is LHD.
Good luck to whoever takes them.
