Headlight wiring diagram help
v8z4
Fountain Hills, AZ
I’m trying to rewire/bridge the headlight and foglight circuits so that:
- Low beams on turns on fogs also (fogs on would NOT turn on low beams)
- With high beams on, the low beams/fogs would remain on
I had planned to just bridge the lows/fogs/highs with diodes appropriately placed, however looking at the wiring diagrams, it looks like the Lighting Switch Cluster directly feeds the headlights (low and high) rather than operating a relay. Is this correct or is there a headlight relay somewhere?
http://wds.spaghetticoder.org/en/svg/sp/SP0000023770.svg?m=e8385
http://wds.spaghetticoder.org/en/svg/sp/SP0000018159.svg?m=e8385
Thanks,
Chris
try checking with ncsexpert coding as bmw coding :
NSW_BEI_ABBLENDLICHT = Front fog lights simultaneously with low beams
NSW_BEI_FL/LH = Front fog lights simultaneously with high beams in FTP
Where would I find those?
I finally found a good copy of NCSExpert and have the programs installed/running. However I'm not getting connection to the vehicle.
I'm trying to use my BMW Scanner Version 1.4.0 cable as the interface cable (since I already own it). Anyone use this cable with NCSExpert?
The cable works with the BMW Scanner software, so I'm trying to figure out if its an incompatability between the NCSExpert-cable or if I don't have something set up right with NCSExpert.
IF the cable is NOT compatible, what is a good (and cheap) cable to get?
checked my fsw_psw.man file and it has the following:
FL_UND_NSW_NICHT_GLEICHZ not active - Front fog lights not simultaneously with high beams
