Headlight washers
Spud
Doncaster
My washers are spraying at my headlights OK, but the resultant spray is landing all over my bonnet. Could the angle on them be slightly out or does everyone else's do this? Never noticed it doing that on my old Z.
Just remember to reconnect before your MOT (if you have xenons) cos it's a fail if your headlight washers don't work (i believe from Jan 12)
Nah, I want to keep them on. They work fine, just wondering if the angle or anything like that could be slightly out? I have an AUC warranty if so.
Use your nails to gently lift the cover and then pull the washer out. You'll see the 2 nozzles. Can't recall if they are adjustable, but you'll soon see.
At said if you do adjust them, the spray will still go over the bonnet and mess everything.
