Headlight problem - sidelight lense out of place
fipsinator
New member
Dear fellow Z drivers,
I've recently discovered that the sidelight lense on my drivers side headlight is out of place what looks like this:
Tested my luck and did a forum search but unfortunately without any usable results.
Maybe someone of you already experienced this problem and can tell me if there is an easier fix then disassemble the headlight to get the lense back in the correct position?
Thank you in advance!
Can you not see it from the back of the headlight, through the access panel? You may have to remove the headlight to see properly. Having said that, I don't know how you will secure it back in place without dismantling the headlight...
