Morning all,
E86 3.0Si.
Does anyone know if both dipped beams are run from the same fuse ? i.e. one of 14, 23 59 or 60. All of the sources I have seen refer only to "light switch cluster"
The off side head light has gone out out and am trying to find the reason. No codes on the Creator C310+. Everything else works fine. My car is slightly non standard in that I installed the Morimoto 5.0 D2S kit in 2019 which has worked very well until a few days ago. I have the car jacked up in the garage to access the drivers side with wheel arch liner and wiring etc. out, but can't get at the passenger side to look at the fuses or substitute the bulb without putting it all back together again and moving the car. As some new bulbs are arriving tomorrow hopefully it would be a pain to reverse it all again.
Many thanks.
E86 3.0Si.
Many thanks.
