Headlight auto levelling
Dukeman
Just got the car back from yet more cost related to the SMG gearbox and hoping for some trouble and cost free motoring. Noticed that the nearside headlamp aim is almost right in front of the car. Usually when you turn the lights on they take a second to light up and seem to rise up to there standard position.
What do you reckon the problem could be? I imagine/ hope it is only the adjuster motor but not sure if there is anything else to check first such as a fuse or the connection. Is there anything else to fault check before replacing the motor.
Advice gratefully received.
If its the adjuster motor for halogen I have one, drop me a PM if interested
This has just happens to me last night, my driver side goes up and levels as normal my passenger side points straight down its like the cars got a wonky eye lol I guess there is some form of control bar that moves the light up and down so going to havd a look today at some point, if anyone has any pointers?
What you're describing is the stepper motor that cycles both xenon and halogen lights from parked position back to operating position. Simply speaking the older systems motor can only find the correct position by cycling. The stepper motor is inside the headlight and connects to the lower part of the light internals and simply moves it back and forth, translating into up /down on the beam.
If just one light is not moving then I'd look for either the motor ball joint connection has become dislodged, loom loose or motor broken. (If both fail which I know is not the case for you and xenons then look to the self levelling sensors on the suspension.)
Take the back off the light and have a tinker, but keep fingers out with the xenons on....
If you're not in a hurry I'll let you have a motor for £10. I've got a box full of spares.
Thanks for the responses. I'm sure the lights are xenons. I will check behind the light first as suggested and then I will hopefully find the problem. As mentioned only the left light fails to 'step' so hopefully it is not the suspension and either the motor or plastic ball joint device.
Thanks for the offers of a spare. If required I shall be in touch.
Cheers.
