Hoping someone here is experienced with this
The aux input on my headunit wasn't working, so I had a few spare minutes to spend inspecting the connections. I pulled out the headunit and followed the cable from the aux port to a large black 'junction' where a lot of cables were plugged in, and they then went directly to the headunit itself. There were two smaller connections, one was the aux cable, the other I don't know where it came from - but it was red & white cables; 3 or 4 I think. Problem is, neither of these two (aux, strange red & white) were then relayed to the headunit. The cables were missing!
Now I can badger the dealer to fix the missing aux cable. However, what does the red & white cable link to? Could it possibly be pre-wired for the CD stacker (not fitted)? If so, would it be an easy job to just get the stacker and hook it up given that the difficult routing is already done?
The aux input on my headunit wasn't working, so I had a few spare minutes to spend inspecting the connections. I pulled out the headunit and followed the cable from the aux port to a large black 'junction' where a lot of cables were plugged in, and they then went directly to the headunit itself. There were two smaller connections, one was the aux cable, the other I don't know where it came from - but it was red & white cables; 3 or 4 I think. Problem is, neither of these two (aux, strange red & white) were then relayed to the headunit. The cables were missing!Now I can badger the dealer to fix the missing aux cable. However, what does the red & white cable link to? Could it possibly be pre-wired for the CD stacker (not fitted)? If so, would it be an easy job to just get the stacker and hook it up given that the difficult routing is already done?
