Hi
I have a hardtop for almost a year, but I came to conclusion its not aligned properly
While putting it on, the front right mount seems to be too much forward, so putting it to its "hole" means the whole hardtop moves backwards for about 2-3mm - it can be easily seen near lower right mount, where the window seal is a bit more backwards then the door seal
I've been trying to readjust the back mounts, but I think the problem is in the top right mount, which should be set backwards a little (like 3-5mm) - easily spoken, but how o adjust the top mount without stripping the hardtop from its lining?
If I'm not describing the problem cloearly then I'll make some photos tomorrow
PS. I've found a similar topic on other forum, which remained unsolved..
I hope its not against forum rules to post a link to another forum..
Here it is:
http://www.zpost.com/forums/showthread.php?t=620793
Here it is:
