What about considering the Bilstein B16 PSS-10? The downside for some, but the upside for others is that the PSS-10 has less settings to fine tune the damper setting. You only have 10 settings between soft and hard. On a V3 and Clubsport you can fine tune your suspension in a more detailed way (if you are a specialist and know what you are doing). The PSS-10 way easier to set up and to experimented with the settings.RedUn said:BMWZ4MC, what settings are you running your clubsports on? Do you leave them on your track settings on the road?
I don't actually mind a firm ride as long as it's well damped and controlled but I know what you are saying, i'll no doubt run with the thicker ARB's and soften the dampers up on the road and then adjust for track/ring use. I'll be going for V3's at a minimum![]()
Good luck on the weight reduction front, it's not a cheap game, I knocked a 100kg out of my S2000 and it cost me a fortune as I wanted to keep the car fully roadworthy inside and not strip it out etc.
Tertius, did you have to pay for the changes to your Intrax or did they do it free of charge?
For me it was a big upside that the Bilstein PSS-10 can be set-up a little higher. My Z4M is now at exactly the same ride height as with my OEM dampers and Eibach springs. I would not want it any lower. Is a Clubsport a suspension that is less versatile considering ride height and always a lot lower then stock (even on highest setting)?Beedub said:my clubsports have completely changed my MR. its a weapon on the track and now with the 18s on, bigger sidewall and and semi slicks I'm shocked how good it feels, i absolutely love the car, and a the suspension mods made the car is always was underneath the bmw stuff. The biggest gripe i have with the clubsport is my car is quite low, however I've managed to get it higher than most coil over setups.
Franzino said:For me it was a big upside that the Bilstein PSS-10 can be set-up a little higher. My Z4M is now at exactly the same ride height as with my OEM dampers and Eibach springs. I would not want it any lower. Is a Clubsport a suspension that is less versatile considering ride height and always a lot lower then stock (even on highest setting)?Beedub said:my clubsports have completely changed my MR. its a weapon on the track and now with the 18s on, bigger sidewall and and semi slicks I'm shocked how good it feels, i absolutely love the car, and a the suspension mods made the car is always was underneath the bmw stuff. The biggest gripe i have with the clubsport is my car is quite low, however I've managed to get it higher than most coil over setups.
exdos said:I think I can sum up here: ANY of the known brands of adjustable suspensions for the Z4M will considerably improve the handling and ride (if set up soft enough for road settings) of the Z4M. All the brands correct the gross imbalance of spring/damper rates of the OEM suspension. It would appear that all of us who have fitted aftermarket suspension are satisfied customers of the respective brands we've fitted and I'm sure that we would also have been satisfied if we'd fitted any of the other brands mentioned in this thread. If you really want to enjoy a considerably improved Z4M then you simply MUST upgrade the suspension. FACT![]()
jimmybell said:Does anyone run KW V3 in a city? or specifically near speed bumps?
There's some pretty aggressive traffic calming measures in SW London... i think the worst speedbumps near me i'd be fine with a 1" lower frontend, but no more. One thing about the Z4MC i really love is how stiff and rigid it is, i want more stiff-and-rigid'ness :evil:
Not fussed about London potholes, i avoid them anyway, but i'd be keen to make sure it handles for B-roads, rather than track tarmac (hence kwv3 may be overkill... maybe just uprating other suspension elements alongside eibachs/H&R's?)
gwatson said:Are adjustable top mounts essential to allow you to dial in a fast road alighnment, or will the OEM top mounts do?
G
exdos said:gwatson said:Likewise, if you want to fit caster/camber plates, adjust caster to get more dynamic camber, rather than adjusting camber, itself.![]()
exdos said:gwatson said:Are adjustable top mounts essential to allow you to dial in a fast road alighnment, or will the OEM top mounts do?
G
Camber/caster plates are not essential. I have them on my Z3MC but have OEM top mounts on my Z4MC. I keep banging the drum that it's toe which makes the most difference to handling, and that's adjusted on the tie rods. Likewise, if you want to fit caster/camber plates, adjust caster to get more dynamic camber, rather than adjusting camber, itself.![]()
gwatson said:Thanks John, that's what I thought\hoped. Although you obviously have the ACS kit. Anyone care to comment specifically on KW's? I know some other suspension kits you need to use aftermarket top mounts.
Car is just about to turn 60k miles, so thinking of replacing the top mounts with news one. Would you recommend that?
I remember on my E36 M3 Evo track car you would fit the left hand top mount to the right hand side and vice a versa, gave a lot more negative camber (and castor I think), was a great tip. Don't think it'll work on the Z4M setup thoughYour Z3M coupe could of be the same!
exdos said:The KW kits can be used with the OEM top mounts, and IIRC, the Clubsport kit is offered with caster/camber plates at a very good price. There would be no harm in fitting new top mounts, and if you do, can I have your old ones to experiment with making some fixed caster plates?
Yes, you can swap the front top mounts of the Z3MC to get over 3 degs of negative camber. I tried it for a while, but I found it far too twitchy for fast road use, so that's when I tried caster/camber plates and found that caster was actually the preferred adjustment. The driving experience is far more relaxed.![]()
tertius said:Yes, I think I know what it is, I'm interested to know how much camber it is possible to achieve by using caster.
gwatson said:So what's a caster plate? Is it effectively an angled spacer?
